Введение
This guide details how to replace the front grille of the Apple iPod Hi-Fi speaker system.
Выберете то, что вам нужно
Take one spudger and fit it under the grille.
Use your first spudger to pry up and make room to insert a second one.
Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
Use the other spudger to raise the grille, allowing you to see where you're working.
5 человек успешно провели ремонт по этому руководству.
