Введение
This is a replacement guide for the external body of the Apple iSight webcam. The external body of the Apple iSight is composed of the silver structure and the cap with the Apple logo. The overall process is quick and easy. Follow these steps for a successful replacement.
Выберете то, что вам нужно
Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
Инструмент, используемый на этом этапе:Tweezers$4.99
Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
Press the Apple logo through to pull apart the body frame from the body of the webcam.
4 человек успешно провели ремонт по этому руководству.
