Archos 101 G9 Battery Replacement
Выберете то, что вам нужно
  1. Archos 101 G9 Battery Replacement, Display Assembly: шаг 1, изображение 1 из 1
    • Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
    • Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
    • When you reach the corner, carefully pry the two halves of the device apart.
    • There are small clips along the edges that need to stay intact in order to properly reassemble the device. Be very gentle when prying so as not to break the clips.
    • Repeat for the remaining three sides and corners.
  2. Archos 101 G9 Battery Replacement: шаг 2, изображение 1 из 2 Archos 101 G9 Battery Replacement: шаг 2, изображение 2 из 2
    • Separate the halves of the device.
    • Ensure that you separate from the top and you keep the bottoms of both pieces near each other so as not to damage the ribbon cables that connect the halves.
  3. Archos 101 G9 Battery Replacement: шаг 3, изображение 1 из 2 Archos 101 G9 Battery Replacement: шаг 3, изображение 2 из 2
    • Gently remove both ribbon cables from their sockets on the motherboard.
  4. Archos 101 G9 Battery Replacement: шаг 4, изображение 1 из 1
    • Remove the white and black coaxial cables with gold tips from the motherboard.
  5. Archos 101 G9 Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the display assembly from the back panel.
  6. Archos 101 G9 Battery Replacement, Battery: шаг 6, изображение 1 из 1
    • Remove the tape covering the solder connections on the motherboard.
  7. Archos 101 G9 Battery Replacement: шаг 7, изображение 1 из 1
    • Desolder the BATT+ connection from the motherboard.
    • Desolder the BATT- connection from the motherboard.
    • Desolder the NTC+ connection from the motherboard.
    • Desolder the NTC- connection from the motherboard.
    • Proceed with caution when using the soldering iron. Try not to damage the connections on the motherboard.
  8. Archos 101 G9 Battery Replacement: шаг 8, изображение 1 из 1
    • Remove the black tape from the top of each battery.
  9. Archos 101 G9 Battery Replacement: шаг 9, изображение 1 из 1
    • Remove the yellow tape from the batteries.
  10. Archos 101 G9 Battery Replacement: шаг 10, изображение 1 из 1
    • Gently pry the batteries away from the case using a nylon spudger.
    • Be very careful not to bend the batteries excessively while doing this.
    • Metal prying tools and other sharp objects may puncture the battery, potentially causing a fire. Always use plastic or nylon prying tools near the battery.
Заключение
Clay Meunier
Участник с: 10/28/21
557 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 Участник UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G1
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24 час(ов): 1
За последние 7 дней: 16
За последние 30 дней: 42
За всё время: 820
