Archos 101 G9 Motherboard Replacement
Выберете то, что вам нужно
  1. Archos 101 G9 Motherboard Replacement, Display Assembly: шаг 1, изображение 1 из 1
    • Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
    • Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
    • When you reach the corner, carefully pry the two halves of the device apart.
    • There are small clips along the edges that need to stay intact in order to properly reassemble the device. Be very gentle when prying so as not to break the clips.
    • Repeat for the remaining three sides and corners.
  2. Archos 101 G9 Motherboard Replacement: шаг 2, изображение 1 из 2 Archos 101 G9 Motherboard Replacement: шаг 2, изображение 2 из 2
    • Separate the halves of the device.
    • Ensure that you separate from the top and you keep the bottoms of both pieces near each other so as not to damage the ribbon cables that connect the halves.
  3. Archos 101 G9 Motherboard Replacement: шаг 3, изображение 1 из 2 Archos 101 G9 Motherboard Replacement: шаг 3, изображение 2 из 2
    • Gently remove both ribbon cables from their sockets on the motherboard.
  4. Archos 101 G9 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Remove the white and black coaxial cables with gold tips from the motherboard.
  5. Archos 101 G9 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Remove the display assembly from the back panel.
  6. Archos 101 G9 Motherboard Replacement, Motherboard: шаг 6, изображение 1 из 1
    • Remove the 2 mm screw that holds the motherboard in place using a Phillips #0 screwdriver.
  7. Archos 101 G9 Motherboard Replacement: шаг 7, изображение 1 из 1
    • Carefully remove the ribbon cable from its socket on the motherboard.
  8. Archos 101 G9 Motherboard Replacement: шаг 8, изображение 1 из 1
    • Remove the tape covering all of the solder connections on the motherboard.
  9. Archos 101 G9 Motherboard Replacement: шаг 9, изображение 1 из 1
    • Desolder all six of the connections that were underneath the tape.
  10. Archos 101 G9 Motherboard Replacement: шаг 10, изображение 1 из 1
    • Remove the motherboard from the tablet.
Заключение
Clay Meunier
Участник с: 10/28/21
557 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 Участник UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G1
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24 час(ов): 0
За последние 7 дней: 6
За последние 30 дней: 13
За всё время: 215
