Неправильные инструменты
Помогите улучшить эту инструкцию — пусть в кадре и в тексте будут правильные инструменты.
Введение
Перейти к шагу 1 ↓This guide will help you replace the screen on your Archos 5 tablet. Although this repair may take some time, don't be discouraged. You can do this yourself!
Выберете то, что Вам нужно
Use the plastic opening tool to take off 3 black sticky pads that cover the screws.
Use the screwdriver(PH000) to remove the screws located under the pads.
Carefully pry open all 4 sides of the Archos 5 using the plastic opening tool.
Once all sides of the device are pried open, gently open the device .
Once you have opened your device, fold the screen away from the battery.
Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece(attached at the bottom of the metallic foil) Press the plastic spudger against the thin black piece and release it.
Peel the plastic screen away from your shattered glass screen, and replace with your new glass screen.
Еще один человек закончил это руководство.
