Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will show you how to replace the motherboard
Выберете то, что вам нужно
Remove the plastic cover over the batteries on both sides of the device.
Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
Remove all four purple bumpers. You may have to bend the metal surround out of the way.
Remove metal surround from the Jukebox. You may have to straighten out tabs that were bent during disassembly.
Desolder the motherboard from the frame at the eight locations shown. You may need to use a desoldering pump.
Desolder the remaining two points on the backside of the Jukebox.
The Motherboard should now be free from the frame and ready for repair or replacement.
