Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Before replacing any components on the Arnova 7K G3 tablet, disassembly is required. That process starts with removing the rear cover to gain access to a majority of the components including the battery, speaker, and logic board.
Запчасти
Детали не указаны.
  1. Remove four 5 mm Phillips #00 screws from each corner of the tablet. Remove four 5 mm Phillips #00 screws from each corner of the tablet. Remove four 5 mm Phillips #00 screws from each corner of the tablet.
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  3. Place the iFixit opening tool in the notches between the cases and pull the covers apart. Place the iFixit opening tool in the notches between the cases and pull the covers apart.
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  4. Repeat step two until 3/4 of the rear cover is unlatched.
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
Заключение
Tyler Sigafoose
Участник с: 19.03.2015
210 Репутация
Автор 2 руководств
Команда
Michigan Tech, Team 1-2, Lauer Spring 2015 Участник Michigan Tech, Team 1-2, Lauer Spring 2015
MTU-LAUER-S15S1G2
2 членов
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 229
