Aroma ARC-914SBD Heating Element/ Thermostat Replacement
Выберете то, что вам нужно
  1. Aroma ARC-914SBD Heating Element/ Thermostat Replacement, Lid: шаг 1, изображение 1 из 2 Aroma ARC-914SBD Heating Element/ Thermostat Replacement, Lid: шаг 1, изображение 2 из 2
    • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
  2. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 2, изображение 1 из 1
    • Once the condensation catcher has been removed, set it aside for reassembly later.
    • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
  3. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 3, изображение 1 из 2 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 3, изображение 2 из 2
    • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 4, изображение 1 из 3 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 4, изображение 2 из 3 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 4, изображение 3 из 3
    • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
  5. Aroma ARC-914SBD Heating Element/ Thermostat Replacement, Heating Element/ Thermostat: шаг 5, изображение 1 из 2 Aroma ARC-914SBD Heating Element/ Thermostat Replacement, Heating Element/ Thermostat: шаг 5, изображение 2 из 2
    • Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry this piece from the bottom to get the tab from behind the stainless steel to in front of the steel as shown.
  6. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 6, изображение 1 из 2 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 6, изображение 2 из 2
    • Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
  7. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 7, изображение 1 из 2 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 7, изображение 2 из 2
    • Using a Phillips head screwdriver, size PH2, remove the screws from the control module to expose wired connections.
  8. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 8, изображение 1 из 1
    • Unplug thermostat from control module
  9. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 9, изображение 1 из 1
    • Remove red and blue wires from heating element to fully detach from control module. This is done by removing the screws on the heating element terminals using a Phillips head screwdriver, size PH2.
  10. Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 10, изображение 1 из 2 Aroma ARC-914SBD Heating Element/ Thermostat Replacement: шаг 10, изображение 2 из 2
    • Again, using a Phillips head screwdriver, size PH2, remove the three screws holding the heating element assembly to the bowl. This will remove the heating element and the thermostat.
Заключение
Еще один человек закончил это руководство.
Brandon Nieves
Участник с: 09/04/15
956 Репутация
Автор 8 руководств
Команда
USF Tampa, Team 2-3, Sullivan Fall 2015 Участник USF Tampa, Team 2-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G3
3 членов
Автор 8 руководств
2 Комментариев
Where do you get a replacement thermostat?
4forums - Ответить
https://www.amazon.com/Aexit-Terminal-Co... or https://www.aliexpress.us/item/225580067... or try googling some combinations of the keywords: 2 pin/wire rice cooker temperature/thermostat magnetic probe/sensor replacement
JAR -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 30
За всё время: 1,966
