Aroma ARC-914SBD Push Button Interface Replacement
Выберете то, что вам нужно
  1. Aroma ARC-914SBD Push Button Interface Replacement, Lid: шаг 1, изображение 1 из 2 Aroma ARC-914SBD Push Button Interface Replacement, Lid: шаг 1, изображение 2 из 2
    • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
  2. Aroma ARC-914SBD Push Button Interface Replacement: шаг 2, изображение 1 из 1
    • Once the condensation catcher has been removed, set it aside for reassembly later.
    • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
  3. Aroma ARC-914SBD Push Button Interface Replacement: шаг 3, изображение 1 из 2 Aroma ARC-914SBD Push Button Interface Replacement: шаг 3, изображение 2 из 2
    • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. Aroma ARC-914SBD Push Button Interface Replacement: шаг 4, изображение 1 из 3 Aroma ARC-914SBD Push Button Interface Replacement: шаг 4, изображение 2 из 3 Aroma ARC-914SBD Push Button Interface Replacement: шаг 4, изображение 3 из 3
    • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
  5. Aroma ARC-914SBD Push Button Interface Replacement, Push Button Interface: шаг 5, изображение 1 из 2 Aroma ARC-914SBD Push Button Interface Replacement, Push Button Interface: шаг 5, изображение 2 из 2
    • Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry the bottom edge of this piece outward (away from the stainless steel side) about 1/4 inch to pull the tab out of it's hole. Once the bottom is pried out a bit, the tab can be seen from the bottom. Press up on the tab with a screwdriver.
  6. Aroma ARC-914SBD Push Button Interface Replacement: шаг 6, изображение 1 из 2 Aroma ARC-914SBD Push Button Interface Replacement: шаг 6, изображение 2 из 2
    • Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
  7. Aroma ARC-914SBD Push Button Interface Replacement: шаг 7, изображение 1 из 2 Aroma ARC-914SBD Push Button Interface Replacement: шаг 7, изображение 2 из 2
    • Using a Phillips head screwdriver, size PH2, remove screws from the control module to expose wired connections.
  8. Aroma ARC-914SBD Push Button Interface Replacement: шаг 8, изображение 1 из 1
    • Unplug the interface from control module.
  9. Aroma ARC-914SBD Push Button Interface Replacement: шаг 9, изображение 1 из 2 Aroma ARC-914SBD Push Button Interface Replacement: шаг 9, изображение 2 из 2
    • Remove the two screws holding the cardboard cover over the Interface using a Phillips head screwdriver, size PH2.
  10. Aroma ARC-914SBD Push Button Interface Replacement: шаг 10, изображение 1 из 2 Aroma ARC-914SBD Push Button Interface Replacement: шаг 10, изображение 2 из 2
    • Using a Phillips head screwdriver, size PH2, remove the four screws holding the interface in place.
Заключение
Еще один человек закончил это руководство.
Brandon Nieves
Участник с: 09/04/15
956 Репутация
Автор 8 руководств
Команда
USF Tampa, Team 2-3, Sullivan Fall 2015 Участник USF Tampa, Team 2-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G3
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 15
За всё время: 488
