Введение
After a few thousand switching operations, the switch of a Tolomeo may no longer function properly. The unit of switch and lamp holder is available from Artemide as a spare part. These instructions show you how to replace it.
Выберете то, что вам нужно
Unscrew the Phillips screw on the clamp. You may have to hold the nut on the opposite side.
The socket is fixed at the top with a wide ring. This ring is secured against unscrewing by a small brass catch.
Press the brass catch with a small flat-blade screwdriver about 1 mm toward the center of the socket. Do not bend the brass catch too much.
Then unscrew the wide ring on the lamp socket.
Here is a picture of the switch. You can buy the complete set quite expensive from Artemide, because the socket has been machined by hand. This has the advantage that you can also renew the socket.
You may also find the switch on its own, which is cheaper. It is a snap-in rocker switch with screw connection. The cutout size is 20 x 14 mm, 15 mm installation depth from the frame. The frame is 3 mm high with the dimensions 26x16 mm. This one could fit.
Work through the steps in reverse order to reassemble your device.
7 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
oldturkey03помогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
9 Комментариев
Thanks for the article. When I get to step 5, I don't see an Allen screw. See the linked images. Do you know how I would remove the cable from the socket?
Thanks!
One more photo:
Socket photo 3
OK, I figured it out, needed to press down on the metal clip in photo 3.
John E. -
Fixed with a white switch.
New white switch.
John E. -
Well done, like it.
VauWeh -
