Введение
This guide shows you how to open up the Arturia Microbrute and remove the bottom plate including the keyboard.
Выберете то, что вам нужно
Switch off the Microbrute and make sure to disconnect any cables.
Don’t forget the mini patch bay on the top right.
Flip the Microbrute over and put it on a soft surface to not damage the knobs and faders.
Use a screwdriver to remove the twelve Philips screws on the bottom plate.
Put the Microbrute on its front edge and carefully tilt open the bottom plate including the keyboard.
Use a spudger to unlock the connector by pushing both left and right locking tabs tabs towards the cable.
Now the Microbrute is open and the bottom plate with the keyboard is separated from the rest of the device.
