Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
All of the key components that could fail are accessed by removing the Aspen A720 back cover. The process will include removing a couple of screws and then utilizing the plastic opening tool to pry the cover apart from the body of the device.
  1. Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button. Make sure to keep track of screws.
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
    • Make sure to keep track of screws.
  2. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  3. Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot. Slide the plastic opening tool around the perimeter of the casing until the back is disconnected. Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  4. Remove the rear casing.
    • Remove the rear casing.
Заключение
Now all of the components are accessible for maintenance
Ben
Участник с: 18.03.2015
280 Репутация
Автор 2 руководств
Команда
Michigan Tech, Team 1-3, Lauer Spring 2015 Участник Michigan Tech, Team 1-3, Lauer Spring 2015
MTU-LAUER-S15S1G3
2 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 263
