Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If you need to replace an damaged or uncomfortable ear cushion for the Astro A20, you will need a spudger and a new ear cushion.
Выберете то, что вам нужно
Place one hand on the hard side of the headset ear portion and on the cushion.
Lift the small portion on the edge of the cushion.
Slide the metal spudger underneath the lift part of the ear cushion.
Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
2 участников успешно повторили данное руководство.
Один комментарий
The lighting is quite poor. I can't see what you're doing at all.
It's also missing a lot of information. Are they glued down? Are you able to get the ear cups off intact so they can be replaced after your wash them?
