Введение
In this step we will be removing all parts necessary to reach the speaker inside each headset. Remember that you can repeat these same steps for each side of the headset if either side needs replacement.
Выберете то, что вам нужно
Pull one corner of the pad to release it from the headset.
Pull the rest of the ear pad off.
Locate the four 4.5 mm Philips #0 screws on the panel shown.
Remove them using a Phillips #0 head screwdriver.
Remove the panel.
Locate the four 4.5 mm Philips #0 screws as shown on the speaker housing.
Remove the four screws using a Phillips #0 head screwdriver.
Еще один человек закончил это руководство.
2 Комментариев
Where do you buy the replacement speaker ? Thanks.
what speakers can these be replaced with? this guide is a little short on details about the actual removal and replacement of the speakers. the information here is just the start
