Astro A50 Astro A50 Speakers Replacement
Выберете то, что вам нужно
  1. Astro A50 Astro A50 Speakers Replacement, Speakers: шаг 1, изображение 1 из 1
    • Carefully remove the ear pad from the speaker that the microphone is attached to. Repeat on the other side.
  2. Astro A50 Astro A50 Speakers Replacement: шаг 2, изображение 1 из 1
    • Remove the four screws from each side of the headset.
  3. Astro A50 Astro A50 Speakers Replacement: шаг 3, изображение 1 из 1
    • After the screws are removed the black piece of the cover can now come off. Remove this piece.
  4. Astro A50 Astro A50 Speakers Replacement: шаг 4, изображение 1 из 2 Astro A50 Astro A50 Speakers Replacement: шаг 4, изображение 2 из 2
    • Then you will see more screws around the now silver edge and a black cushioning pad in the middle. The number of screws depends on the speaker you are replacing, one side has 2 screws while the other has 4.
  5. Astro A50 Astro A50 Speakers Replacement: шаг 5, изображение 1 из 1
    • Remove the screws in the silver edge.
  6. Astro A50 Astro A50 Speakers Replacement: шаг 6, изображение 1 из 1
    • Once the screws are removed, the speaker should come out now.
    • Note: the speaker might still be connected to the headset through a wire so you must be gentle pulling about the headset.
  7. Astro A50 Astro A50 Speakers Replacement: шаг 7, изображение 1 из 1
    • After that take off the cover. If the speaker is still connected and no wires are visibly damaged, then the speaker(s) is not the problem with your device. Please refer back to the troubleshooting page and make sure that the Astro A50 has the newest firmware, etc. If the wire is not connected continue to the next step.
  8. Astro A50 Astro A50 Speakers Replacement: шаг 8, изображение 1 из 2 Astro A50 Astro A50 Speakers Replacement: шаг 8, изображение 2 из 2
    • To reconnect the wire you will need to solder the wire back to the mic port. If you need help soldering refer to the soldering guide here.
    • Note: soldering is very dangerous and should not be done without supervision if you have never done it before.
    • After that put the headset back together, check to verify that the speaker is working.
  9. Astro A50 Astro A50 Speakers Replacement: шаг 10, изображение 1 из 1
    • If there is still no sound or static, then the speaker might be “blown” and/or needs to be replaced completely. If so, please order a new speaker and follow the same steps to replace the whole speaker.
Заключение
3 участников успешно повторили данное руководство.
Ramzi Bechara
Участник с: 10/28/15
155 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team 2-5, Shastany Fall 2015 Участник UMass Dartmouth, Team 2-5, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G5
4 членов
Автор 10 руководств
4 Комментариев
Great info and well explained. would you know where I could purchase a speaker?
nvandyk7 - Ответить
I I have problem with my astro a50 ps4 I hear good but when I want talk to someone no one hears me please I want to solve, note the headset did not fall or be damaged!! Help me please
Omar - Ответить
i blew out the left side of my earphone astro a50 for xbox one/pc and i wish i could order the parts but astro said they dont have a repair shop or parts. and that they will sell me a new one for a discounted price. that sucks
chris needham - Ответить
Hi I need the part that holds the bar to head band part as mine has snapped
ERAGAMING97 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 30
За всё время: 9,948
