Введение
The guide allows for you to take apart and replace the channel selection switch on an Astro A50 gaming headset with only a Phillips head screwdriver.
Выберете то, что вам нужно
Remove the four 3.5mm Phillips head screws circled in red, and remove the grey cover
Remove the four 3.5mm Phillips head screws circled in red and remove the silver cover.
Remove the motherboard remove the four 3.5mm long Phillips head screws circled in red.
Remove the 3.5mm Phillips head screw circled in blue to remove secondary motherboard.
Separate the secondary mother board from the motherboard by pulling firmly to the right on the white connector.
Еще один человек закончил это руководство.
