Введение
This guide will show the user how to remove the front secret trim. The only tool needed is a spudger which will be used to push up the tabs connecting the screen to the base of the laptop.
Выберете то, что вам нужно
Push the two tabs located below the battery in towards each other using your thumbs.
Continue to push the battery upwards until it is completely separated from the laptop as shown.
Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
When the screen case has been successfully removed, the laptop should resemble the photo shown here.
2 участников успешно повторили данное руководство.
