Введение
After the battery has been removed, this guide will show the user how to remove the keyboard. A spudger and a screwdriver will be needed for this guide.
Выберете то, что вам нужно
Push the two tabs located below the battery in towards each other using your thumbs.
Continue to push the battery upwards until it is completely separated from the laptop as shown.
Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
After all four screws are removed, flip the laptop over with the keyboard facing up.
Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
2 участников успешно повторили данное руководство.
