Введение
Remove the lower case of the ASUS A52F XE2 to gain access to internal parts.
Выберете то, что вам нужно
Place the laptop face down with the battery facing away from you.
Locate the two buttons next to the battery.
Slide the right slider to the unlocked (red) position.
Hold the left button to the left.
Slide the battery with your other hand away from you and it should disconnect.
Remove the five Phillips # 0 screws from the back panel.
Using your finger or a plastic spudger start to carefully pry up the back planel.
Еще один человек закончил это руководство.
