Введение
A malfunctioning hard drive can be the underlying cause of many issues with your laptop. This guide will explain how to replace your hard drive.
Запчасти
Никакие детали не требуются.
  1. Make sure the laptop is off.
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Move the two sliders towards the outer edge of the laptop.
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the hard drive panel.
    • Pull upwards on the black ribbon on the end of the hard drive.
    • Pull the hard drive out from its socket and remove it from the device.
Заключение
Chase Poirier
Участник с: 23.10.2018
481 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 Member of UMass Dartmouth, Team S1-G3, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G3
3 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 11
За всё время: 49
