Введение
Replacing the Asus Chromebook C101P touchpad is a simple procedure, so if you ever spill liquid onto your touchpad and it refuses to work anymore, don’t be scared. With just a few steps, you’ll be able to have a functioning touchpad again. It is important that you unplug and shut your Chromebook off before attempting this replacement in order to prevent electrocuting yourself.
Выберете то, что вам нужно
Flip the Chromebook so that the bottom is facing up.
Remove the nine T5 Torx screws.
Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
Reorient the Chromebook so the right side is facing upwards.
Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
Инструмент, используемый на этом этапе:Tweezers$4.99
Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
Separate the keyboard from the rest of the laptop.
