Asus Chromebook C202 Input/Output board Replacement
Выберете то, что вам нужно
  1. Asus Chromebook C202 Input/Output board Replacement, Back Panel: шаг 1, изображение 1 из 2 Asus Chromebook C202 Input/Output board Replacement, Back Panel: шаг 1, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Phillips #1 Screwdriver
    $5.49
    Купить
    • Remove ten 8 mm Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
  2. Asus Chromebook C202 Input/Output board Replacement: шаг 2, изображение 1 из 1
    iFixit Opening Tool
    $1.99
    Купить
    • Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
    • Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
    • Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
  3. Asus Chromebook C202 Input/Output board Replacement: шаг 3, изображение 1 из 1
    • Gently disconnect the ribbon cable connecting the trackpad to the motherboard.
    • Gently disconnect the ribbon cable connecting the keyboard to the motherboard.
  4. Asus Chromebook C202 Input/Output board Replacement, Battery: шаг 4, изображение 1 из 3 Asus Chromebook C202 Input/Output board Replacement, Battery: шаг 4, изображение 2 из 3 Asus Chromebook C202 Input/Output board Replacement, Battery: шаг 4, изображение 3 из 3
    • Pull the latch out on both the Input/Output board as well as the motherboard.
    • Gently remove the ribbon cable connecting the I/O board to the motherboard.
  5. Asus Chromebook C202 Input/Output board Replacement: шаг 5, изображение 1 из 3 Asus Chromebook C202 Input/Output board Replacement: шаг 5, изображение 2 из 3 Asus Chromebook C202 Input/Output board Replacement: шаг 5, изображение 3 из 3
    • Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
    • Remove metal grate from battery.
    • Remove six 4 mm Phillips #1 screws from the battery
  6. Asus Chromebook C202 Input/Output board Replacement: шаг 6, изображение 1 из 2 Asus Chromebook C202 Input/Output board Replacement: шаг 6, изображение 2 из 2
    • Disconnect the battery from the motherboard.
    • Lift battery from the bottom portion of the Chromebook.
  7. Asus Chromebook C202 Input/Output board Replacement: шаг 7, изображение 1 из 1
    • Remove the battery from the Chromebook.
  8. Asus Chromebook C202 Input/Output board Replacement, Input/Output board: шаг 8, изображение 1 из 2 Asus Chromebook C202 Input/Output board Replacement, Input/Output board: шаг 8, изображение 2 из 2
    • Remove 2 4 mm Phillips #1 screws connecting the I/O board to the Chromebook.
    • Lift the I/O board from the Chromebook.
Заключение
2 участников успешно повторили данное руководство.
Christopher Segale
Участник с: 09/28/16
883 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 3-1, Passmore Fall 2016 Участник USF Tampa, Team 3-1, Passmore Fall 2016
USFT-PASSMORE-F16S3G1
4 членов
Автор 16 руководств
Один комментарий
Thanks for all your ASUS guides — saved me a packet when my son breaks his!
Nick Huggett - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 1,027
