Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Sometimes your camera can become damaged and need replacing. Note: if your device locates the camera, you may not actually need to replace the hardware. If you do, though, this guide is for you!
Запчасти
Детали не указаны.
  1. Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  4. Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
  5. Using the spudger, disconnect the cable from the camera.  The camera will then pop out.
    • Using the spudger, disconnect the cable from the camera. The camera will then pop out.
Заключение
Beau Hansen
Участник с: 28.09.2017
836 Репутация
Автор 7 руководств
Команда
Idaho State University, Team S4-G4, Watkins Fall 2017 Участник Idaho State University, Team S4-G4, Watkins Fall 2017
ISU-WATKINS-F17S4G4
4 членов
Автор 13 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 11
За последние 30 дней: 26
За всё время: 304
