Введение
This guide will show how to replace the LCD screen for the device. Note that the screen is only one piece of the total display, for which there is another guide.
Инструменты
Запчасти
Детали не указаны.
Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
Fold down screen and remove the screen connector band. You may have to use a small flat blade or a spudger, since the latch is very small.
4 участников успешно повторили данное руководство.
