Asus Chromebook C300MA-DH02 Battery Replacement
Выберете то, что вам нужно
  1. Asus Chromebook C300MA-DH02 Battery Replacement, Keyboard Panel: шаг 1, изображение 1 из 3 Asus Chromebook C300MA-DH02 Battery Replacement, Keyboard Panel: шаг 1, изображение 2 из 3 Asus Chromebook C300MA-DH02 Battery Replacement, Keyboard Panel: шаг 1, изображение 3 из 3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Battery Replacement: шаг 2, изображение 1 из 1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Battery Replacement: шаг 3, изображение 1 из 2 Asus Chromebook C300MA-DH02 Battery Replacement: шаг 3, изображение 2 из 2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Battery Replacement, Battery: шаг 4, изображение 1 из 2 Asus Chromebook C300MA-DH02 Battery Replacement, Battery: шаг 4, изображение 2 из 2
    • Remove (6) six "4mm" screws that hold the battery using the Phillips #000 screwdriver.
  5. Asus Chromebook C300MA-DH02 Battery Replacement: шаг 5, изображение 1 из 1
    • Placing two plastic opening tools on each side of the battery connector and gently pull with an even force on both sides of the connector until the connector pops out.
  6. Asus Chromebook C300MA-DH02 Battery Replacement: шаг 6, изображение 1 из 1
    • Note: Your battery may have adhesive on the underside. If you cannot easily remove the battery you can use a hair dryer to evenly warm the glue.
    • Remove the battery by applying even force on both sides.
    • During reassembly, purchase of adhesive may be necessary.
Заключение
Еще один человек закончил это руководство.
Zachary Leonard
Участник с: 10/02/17
304 Репутация
Автор 3 руководств
Команда
USF Tampa, Team S6-G4, Remmell Fall 2017 Участник USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 216
