Введение
This guide will demonstrate how to safely remove the battery from your Asus Chromebook C300SA-DS02. This step by step process is simple and should take no longer then five minutes. All of the screws holding the device together are documented by the correct type during the correct step. Make sure to keep track of them throughout the guide.
Выберете то, что вам нужно
Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
Remove the three 6.0mm Phillips #0 screws.
Open the laptop.
Using an iFixit opening tool, pry along the edges of the keyboard.
Lift the keyboard and slide it gently towards you.
Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
Еще один человек закончил это руководство.
