Введение
This prerequisite is required in order to replace or fix some components inside the bottom of the computer.
Выберете то, что вам нужно
Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
11 участников успешно повторили данное руководство.
Один комментарий
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
