Введение
In this replacement guide, you will be instructed on the process of removing the back plate, making sure the laptop is turned off and not connected to a power source and removing the necessary components are removed so that the charging port can be removed and eventually replaced.
Выберете то, что вам нужно
Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
Remove the five screws from beneath the rubber feet using a Phillips #0 screwdriver.
Remove the nine bottom cover screws using a T5 screwdriver.
Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them.
Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require extra power.
Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
Disconnect the DC jack cable and the battery cable from the motherboard using tweezers, the pointed end of a plastic spudger, or by simply pulling the cables apart from the motherboard with your fingers.
Using a pair of tweezers or your fingers, lift up the charging cable and remove the charging port.
10 участников успешно повторили данное руководство.
Один комментарий
I just did this but now when I turn it on there is no picture on the computer. I had to change the charging port because my cats knocked over a water glass. The charging port was successful because the light was on. Amy troubleshooting?
