Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide contains numerous steps and will require an extensive amount of time. You'll need access to a T5 Torx screwdriver to complete this process. Make sure your device is unplugged and turned off to proceed with the guide.
Выберете то, что вам нужно
Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
Remove the five screws from beneath the rubber feet using a Phillips #0 screwdriver.
Remove the nine bottom cover screws using a T5 screwdriver. Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them.
Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require extra power. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
Disconnect the DC jack cable and the battery cable from the motherboard using tweezers, the pointed end of a plastic spudger, or by simply pulling the cables apart from the motherboard with your fingers.
Disconnect the LCD cable from the motherboard using the pointed end of a plastic spudger.
Disconnect the motherboard to powerboard cable from the motherboard using the pointed end of a plastic spudger.
Disconnect the digitizer board cable from the motherboard using the pointed end of a plastic spudger.
Disconnect the two WiFi antenna cables from the motherboard using the pointed end of a plastic spudger or simply by pulling the cables apart from the motherboard with your fingers.
Disconnect the speaker cable from the motherboard using the pointed end of a plastic spudger.
Remove the four 4.2mm speaker screws, then remove the two speakers using a philips head screwdriver.
Remove the two 2.7mm heat sink screws with a T5 screwdriver, then remove the heat sink from the motherboard.
2 участников успешно повторили данное руководство.
