Asus Chromebook Flip C100P Motherboard Replacement
Выберете то, что вам нужно
  1. Asus Chromebook Flip C100P Motherboard Replacement, Motherboard: шаг 1, изображение 1 из 1
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Motherboard Replacement: шаг 2, изображение 1 из 1
    • Remove the five screws from beneath the rubber feet using a Phillips #0 screwdriver.
    • The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Motherboard Replacement: шаг 3, изображение 1 из 1
    • Remove the nine bottom cover screws using a T5 screwdriver. Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them.
    • Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them
  4. Asus Chromebook Flip C100P Motherboard Replacement: шаг 4, изображение 1 из 3 Asus Chromebook Flip C100P Motherboard Replacement: шаг 4, изображение 2 из 3 Asus Chromebook Flip C100P Motherboard Replacement: шаг 4, изображение 3 из 3
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require extra power. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Motherboard Replacement: шаг 5, изображение 1 из 3 Asus Chromebook Flip C100P Motherboard Replacement: шаг 5, изображение 2 из 3 Asus Chromebook Flip C100P Motherboard Replacement: шаг 5, изображение 3 из 3
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Motherboard Replacement: шаг 6, изображение 1 из 3 Asus Chromebook Flip C100P Motherboard Replacement: шаг 6, изображение 2 из 3 Asus Chromebook Flip C100P Motherboard Replacement: шаг 6, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Disconnect the DC jack cable and the battery cable from the motherboard using tweezers, the pointed end of a plastic spudger, or by simply pulling the cables apart from the motherboard with your fingers.
  7. Asus Chromebook Flip C100P Motherboard Replacement: шаг 7, изображение 1 из 2 Asus Chromebook Flip C100P Motherboard Replacement: шаг 7, изображение 2 из 2
    • Disconnect the LCD cable from the motherboard using the pointed end of a plastic spudger.
  8. Asus Chromebook Flip C100P Motherboard Replacement: шаг 8, изображение 1 из 2 Asus Chromebook Flip C100P Motherboard Replacement: шаг 8, изображение 2 из 2
    • Disconnect the motherboard to powerboard cable from the motherboard using the pointed end of a plastic spudger.
  9. Asus Chromebook Flip C100P Motherboard Replacement: шаг 9, изображение 1 из 2 Asus Chromebook Flip C100P Motherboard Replacement: шаг 9, изображение 2 из 2
    • Disconnect the digitizer board cable from the motherboard using the pointed end of a plastic spudger.
  10. Asus Chromebook Flip C100P Motherboard Replacement: шаг 10, изображение 1 из 1
    • Disconnect the two WiFi antenna cables from the motherboard using the pointed end of a plastic spudger or simply by pulling the cables apart from the motherboard with your fingers.
  11. Asus Chromebook Flip C100P Motherboard Replacement: шаг 11, изображение 1 из 2 Asus Chromebook Flip C100P Motherboard Replacement: шаг 11, изображение 2 из 2
    • Disconnect the speaker cable from the motherboard using the pointed end of a plastic spudger.
  12. Asus Chromebook Flip C100P Motherboard Replacement: шаг 12, изображение 1 из 3 Asus Chromebook Flip C100P Motherboard Replacement: шаг 12, изображение 2 из 3 Asus Chromebook Flip C100P Motherboard Replacement: шаг 12, изображение 3 из 3
    • Remove the four 4.2mm speaker screws, then remove the two speakers using a philips head screwdriver.
  13. Asus Chromebook Flip C100P Motherboard Replacement: шаг 13, изображение 1 из 2 Asus Chromebook Flip C100P Motherboard Replacement: шаг 13, изображение 2 из 2
    • Remove the five 2.7mm motherboard screws with a T5 screwdriver.
  14. Asus Chromebook Flip C100P Motherboard Replacement: шаг 14, изображение 1 из 1
    • Remove the motherboard.
Заключение
To reassemble your device, replace the broken or faulty motherboard with a new motherboard and follow these instructions in reverse order.
3 человек успешно провели ремонт по этому руководству.
Andrew Acton
Участник с: 03/19/18
469 Репутация
Автор 2 руководств
Команду
Baylor, Team S5-G2, Williams Spring 2018 Участник Baylor, Team S5-G2, Williams Spring 2018
BU-WILLIAMS-S18S5G2
3 членов
Автор 8 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 25
За всё время: 2,644
