Asus Chromebook Flip C100P Power and Volume Buttons Replacement
Выберете то, что вам нужно
  1. Asus Chromebook Flip C100P Power and Volume Buttons Replacement, Power and Volume Buttons: шаг 1, изображение 1 из 1
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 2, изображение 1 из 1
    • Remove the five screws from beneath the rubber feet using a philips head screwdriver. The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 3, изображение 1 из 1
    • Remove the eight 3mm bottom cover screws and one 6mm screw using a T5 screwdriver. Set apart the screw in the rear middle of the bottom cover from the the other eight screws, as it is longer than them.
  4. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 4, изображение 1 из 3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 4, изображение 2 из 3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 4, изображение 3 из 3
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require a bit of elbow grease. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 5, изображение 1 из 3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 5, изображение 2 из 3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 5, изображение 3 из 3
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 6, изображение 1 из 2 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 6, изображение 2 из 2
    • Flip up the white part of the connector using the pointed end of a plastic spudge.
  7. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 7, изображение 1 из 1
    • Pull the cable out by the blue tab.
  8. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 8, изображение 1 из 1
    • Unscrew two 2.7 mm screws using the Phillips #0 screwdriver.
  9. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 9, изображение 1 из 1
    • Remove the button chip.
  10. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: шаг 10, изображение 1 из 1
    • Using tweezers, carefully pull out the external buttons.
Заключение
Еще один человек закончил это руководство.
Andrew Thomson
Участник с: 03/19/18
181 Репутация
1 руководство автора
Команда
Baylor, Team S5-G2, Williams Spring 2018 Участник Baylor, Team S5-G2, Williams Spring 2018
BU-WILLIAMS-S18S5G2
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 778
