Введение
Does your computer shut down often? Is your screen and/or your sound not working? Do you get a lot of error messages or random crashes? It might not be a problem with the computer as a whole, but rather an issue with the motherboard. This piece of tech is integral to all the parts of a computer "communicating" properly, so when it's damaged, it might result in any of these symptoms. This guide will teach you how to replace the mother/daughterboard for your ASUS Chromebook Flip C302CA.
Выберете то, что вам нужно
With the T5 Torx Screwdriver, remove the ten 5 mm screws from the back panel.
Remove the rubber caps at the top of the panel. Then, using the Phillips #00 Screwdriver, remove the two 1 mm screws underneath.
Lift up the back panel.
Remove the four 2.5 mm screws securing the battery
Remove the connector from the motherboard by pulling straight up on it.
Carefully lift the battery out of the laptop.
Gently lift the white tab highlighted in the image. Then, disconnect the blue connector by pulling away from the motherboard.
Gently lift the black tab highlighted in the photo. Then, repeat the same process mentioned above.
Once again, lift the white tab highlighted in the image. Then, pull the brown connector away to disconnect it from the motherboard.
With the Phillips #00 Screwdriver, remove the two highlighted 1 mm screws attaching the heatsink (highlighted in orange) to the motherboard.
Then, remove the heatsink from the motherboard.
With the Philips-Head #00 Screwdriver, remove the eleven 2.5 mm screws that secure the motherboard.
With the same tool, remove the four 1.3 mm screws at the bottom of the mother board/daughterboard.
Replace the motherboard/daughterboard.
