Введение
If the speakers in your Asus Chromebook Flip laptop (model C302CA) has no vibration, is disrupting without turning up the volume too high, is making noises like popping and rattling, or the system range is unsatisfactory, it is likely blown and needs to be replaced.
It is essential that you replace it if it is broken because it improves the sound quality of your computer. It also provides audio for your online meeting(s) (if you happen to have them).
With this in mind, make sure your laptop is turned off and unplugged from any outlets before removing the components.
Additionally, before you start to replace this component, gather all of your tools in one location. To keep your screws from getting lost, we recommend using the iFixit Magnetic Project Mat. Choose a location where there will be no children to interrupt you to prevent them from using potentially dangerous tools.
Выберете то, что вам нужно
Remove two rubber caps on the top.
Remove the two 1 mm screws using the Phillips #00 screwdriver.
Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
Carefully remove the back panel using an opening pick.
Remove the sticker holding the cable using a pair of tweezers.
Detach the cable from the motherboard by lifting it up with a spudger.
Remove the two 2 mm screws holding the battery using a Phillips #00 screwdriver.
Remove the two 2 mm screws from the speakers using a Phillips #00 screwdriver.
Detach the cable that is connected to the motherboard using a pair of blunt tweezers.
