Введение
This guide will show you how to replace the hard drive. Please see the proper list of tools so you are prepared.
Выберете то, что вам нужно
Remove the battery before working on your device. See this LINK for a step-by-step guide.
Gently turn the laptop up side down so that the battery is facing away from you. The battery is outlined by the red rectangle in the picture to the left.
Use a #00 Phillips Head screw driver to remove the two 1/4" screws that hold the back panel in place.
Place the blue plastic 1/4" opening tool into the small indention and gently pry the back panel off.
2 участников успешно повторили данное руководство.
