Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace the keyboard in the Asus Eee PC 1005HA.
Выберете то, что вам нужно
Slide the tabs outward to unlock the battery.
Holding the right tab open, slide the battery out of the laptop.
The first step is to remove the battery from the laptop.
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Flip the laptop over, and open the display.
Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
Gently lift the keyboard and slide it toward the screen.
Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
Once the ZIF connector tabs have been released, remove the keyboard.
12 участников успешно повторили данное руководство.
Один комментарий
after i upgrade my bios keyboard stop working . but external keyboard working fine.. plz help
