Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Lay the laptop upside down.
Locate the two battery lock tabs.
Slide the tabs outward to unlock the battery.
Holding the right tab open, slide the battery out of the laptop.
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Flip the laptop over, and open the display.
Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
Gently lift the keyboard and slide it toward the screen.
Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
Once the ZIF connector tabs have been released, remove the keyboard.
12 участников успешно повторили данное руководство.
Один комментарий
after i upgrade my bios keyboard stop working . but external keyboard working fine.. plz help
