Введение
Use this guide to replace or upgrade RAM in the Asus Eee PC 1005HA.
  1. Loosen the captive screw in the RAM compartment cover. Remove the RAM compartment cover. This photo shows the battery still attached, but it should be removed prior to removing or replacing the RAM.
    • Loosen the captive screw in the RAM compartment cover.
    • Remove the RAM compartment cover.
    • This photo shows the battery still attached, but it should be removed prior to removing or replacing the RAM.
  2. Pull the two RAM retaining arms away from the center of the RAM chip. Gently pull the RAM chip out of its socket. Gently pull the RAM chip out of its socket.
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • Gently pull the RAM chip out of its socket.
Заключение
7 участников успешно повторили данное руководство.
Mitchell Cesare
Участник с: 31.01.2012
757 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 11-22, Maness Winter 2012 Участник Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 членов
Автор 12 руководств
Один комментарий
Great guides. What is the maximum amount of RAM that this unit can accept?
MalikDon777 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 10,555
