Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Lay the laptop upside down.
Locate the two battery lock tabs.
Slide the tabs outward to unlock the battery.
Holding the right tab open, slide the battery out of the laptop.
Using tweezers, remove the six screw covers on the screen bezel.
Remove the six 4.6 mm screws from the bezel.
Use a plastic opening tool to disengage the plastic clips that secure the screen bezel to the display.
Carefully remove the bezel from the display.
Remove the four 3.6 mm screws securing the screen.
Slowly lift the screen up from the rest of the laptop.
Remove the plastic tape securing the display cables to the back of the screen.
Slide the display cable connector out its socket on the back of the screen.
Remove the four 3.1 mm housing screws on the sides of the display housing frame
Remove the housing frame.
13 участников успешно повторили данное руководство.
