Asus Eee PC 1008ha Cooling Fan Replacement
Выберете то, что вам нужно
  1. Asus Eee PC 1008ha Cooling Fan Replacement, Battery: шаг 1, изображение 1 из 1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Cooling Fan Replacement: шаг 2, изображение 1 из 3 Asus Eee PC 1008ha Cooling Fan Replacement: шаг 2, изображение 2 из 3 Asus Eee PC 1008ha Cooling Fan Replacement: шаг 2, изображение 3 из 3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Cooling Fan Replacement: шаг 3, изображение 1 из 2 Asus Eee PC 1008ha Cooling Fan Replacement: шаг 3, изображение 2 из 2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Cooling Fan Replacement, Cooling Fan: шаг 4, изображение 1 из 3 Asus Eee PC 1008ha Cooling Fan Replacement, Cooling Fan: шаг 4, изображение 2 из 3 Asus Eee PC 1008ha Cooling Fan Replacement, Cooling Fan: шаг 4, изображение 3 из 3
    • Use the Phillips #0 screwdriver to remove the two 2mm screws from the copper heat sink. These are found on the left side of the device.
    • Make sure to remove the adhesive tape from the top of the heat sink.
  5. Asus Eee PC 1008ha Cooling Fan Replacement: шаг 5, изображение 1 из 2 Asus Eee PC 1008ha Cooling Fan Replacement: шаг 5, изображение 2 из 2
    • Remove the small white connector attached to the fan. Make sure to carefully pull from the white connector. Do not pull the connecting wires, as this can cause damage to the component.
    • Replace with new cooling fan!
Заключение
To reassemble your device, follow these instructions in reverse order. If your device is still having issues after replacing the cooling fan, ensure the device is powered off and carefully follow this guide from the beginning; you may have misplaced something. We hope this guide has served as a helpful resource in replacing your Asus Eee PC 1008ha cooling fan!
2 участников успешно повторили данное руководство.
Michael Dooley
Участник с: 04/18/13
138 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 21-52, Johann Spring 2013 Участник Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 членов
Автор 11 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,727
