Введение
You will be the remove of the battery and continue to cautiously take the graphics card off of the laptop. This installation would be necessary if a user has a fried, defected, or inoperative in general.
Выберете то, что вам нужно
Using the plastic opening tool, carefully pry the top panel from the base.
Lift the side of the keyboard.
Disconnect the attached ribbon located underneath the keyboard.
Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
Use your fingers to lift the battery and gently disconnect the wires from the base.
Flip over the graphics card.
Pull the black plastic locking mechanism towards the golden ribbon to unlock.
Pull out the ribbon.
Еще один человек закончил это руководство.
Один комментарий
Is this the graphics card?
Is this pc has no integrated graphics card?
