Введение
Overheating is one of the main issues with computers. This guide will demonstrate how to replace the fan in your Asus Eee PC 1201N.
Выберете то, что вам нужно
Open the netbook to find the four small grooves along the top of the keyboard.
Pry the keyboard up using the plastic opening tool.
Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
Remove the keyboard.
Remove the eight 6.5mm screws using the J0 Phillips head screwdriver from back of the netbook.
Remove the ten 4.5 mm screws from cover plate using the J0 Phillips head screwdriver.
Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
Pull the blue tab for the touchpad connector before removing the cover plate completely.
Remove the two 4.6 mm screws from the cover plate using the J0 Phillips head screwdriver.
Еще один человек закончил это руководство.
