Введение
In the event that your Asus Eee PC 1201N's hard drive is faulty this guide will show you exactly how to do that. It will only require a screwdriver and a plastic opening tool.
Выберете то, что вам нужно
Open the netbook to find the four small grooves along the top of the keyboard.
Pry the keyboard up using the plastic opening tool.
Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
Remove the keyboard.
Turn the netbook over and remove the eight 6.5mm screws using the J0 Phillips head screwdriver.
Turn the netbook back over and remove the ten 4.5mm screws using the J0 Phillips head screwdriver.
Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
Flip up the retaining flap on the ZIF connector. Then, pull the blue tab for the touchpad connector before removing the cover plate completely.
Slide the hard drive to the right and then lift it straight out of the netbook.
4 участников успешно повторили данное руководство.
