Введение
If your keyboard is not working anymore you can easily replace the whole keyboard by following these few steps. Be sure to be careful when removing the keyboard that you do not pull it too far up before unlocking the ribbon connecting it to the motherboard.
Выберете то, что вам нужно
Open the netbook to find the four small grooves along the top of the keyboard.
Pry the keyboard up using the plastic opening tool.
Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
Remove the keyboard.
Еще один человек закончил это руководство.
