Введение
Removing the top cover is a mandatory step before to access the keyboard screw and go deeper inside the Eee PC 1215N.
Выберете то, что вам нужно
Turn the power off and turn the netbook upside down.
Slide both battery catches together to release the battery.
Slide the battery out.
Locate the memory compartment.
Using a Plastic Opening Tools, remove the screw rubber cover.
Remove the screw.
Use a Plastic Opening Tools near the screw hole to release the cover.
Remove the cover
Remove the screws as necessary.
For top cover removing, only remove the 2 bottom screws.
The one short screw paterns to uper left screw hole directly on the PCB.
Use a Plastic Opening Tools to release the top cover.
Start from the left side.
Go around on the bottom
Finish with the right side.
