Введение
RAM acts as temporary storage on your device that will occasionally fault or run out of memory. If you need to replace or install new RAM on your Asus Eee PC 900, follow the directions below. Before beginning, make sure the device is powered off and is not connected to any power source.
Выберете то, что вам нужно
Slide the battery's locking tabs from the locked position to unlocked positions.
Slide the battery out while holding the left locking tab in the unlocked position.
Open up the cover from the bottom by carefully prying it open with a plastic opening tool.
Use a spudger to push the top of the pin on the right towards the right (so it isn't holding the RAM chip).
Do the same for the left pin. Push the top of the pin towards the left.
5 участников успешно повторили данное руководство.
