Введение
This guide will help you replace your Asus EeeBook X205TA trackpad in case it is worn out, damaged, or isn't working. If disposing trackpad , please follow the laws and regulations for proper disposal.
Выберете то, что вам нужно
Unscrew all 10 screws located on the bottom of the laptop using a Phillips #2 Screwdriver.
Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
Carefully pry open the case from several points.
Unscrew the four screws using Philips #2 screwdriver located around the edge of the USB ports.
Unplug the battery ZIF connector from the USB ports.
3 участников успешно повторили данное руководство.
