Введение
In this guide you will learn how to replace the speakers in an Asus EeeBook X205TA.
Выберете то, что вам нужно
Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
Carefully pry open the case from several points.
Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
Locate and lift the tabs from the LED/motherboard ribbon cable.
Remove the cable.
Еще один человек закончил это руководство.
2 Комментариев
Thanks. You’ve helped make it clearer for me!
