Введение
Many of the Asus F554LA-WS52 notebook's components take several steps to remove and replace. This sequential guide shows the necessary steps. For this guide, you will need a plastic opening tool and a Phillips #00 screwdriver head.
Выберете то, что вам нужно
Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
With a plastic opening tool, gently lift and remove the back cover to expose the internal components.
Unscrew the three 5.7 mm hard drive-motherboard connection screws with a #0 Phillips head screwdriver.
Remove the small rectangular hard drive-motherboard connection board.
Unscrew the four 5.7 mm battery screws with a #0 Phillips head screwdriver.
Remove the battery.
Unscrew the two 2.7 mm and one 5.7 mm CD drive screws with the Phillips #00 screwdriver.
With the plastic opening tool, gently pry the drive out from the metal brackets that hold it in place.
2 участников успешно повторили данное руководство.
