Введение
You may need to replace your notebook's screen if it is scratched or cracked, but have an otherwise intact notebook. A simple fix, you will need a plastic opening tool and Phillips #0 screwdriver.
Выберете то, что вам нужно
Remove the two plastic screw coverings from the bottom of the screen panel.
Using the plastic opening tool, gently pry the notebook's plastic screen covering away from the screen.
Remove tape that covers the visual pin connectors.
Gently disconnect the screen from the pin connectors and replace.
