Введение
In this guide we will show you how to properly remove and replace the hard drive in your Asus F555LA-AB31 laptop..
Hard drive replacements are needed when old drives begin to die or fail altogether. You’ll notice a hard drive beginning to fail when your laptop crashes during booting, or when it takes a lot longer for a file to open. You may also be replacing the hard drive with one that has increased storage. In either case, you’ll want to follow our instructions.
It is recommended that you know how to operate a screwdriver to easily open up the laptop as well as have an anti-static wristband to prevent damage to the internals of your laptop from any built up static charges.
Выберете то, что вам нужно
Carefully fold the device open.
Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
Еще один человек закончил это руководство.
Один комментарий
Boo, 10 screws in first step are not all the same length, 4 screws in third step are not correctly indicated in the image (nor are they all in view in said image). Finally, there’s a hard drive bracket that is not included in the guide which is important to note how it is positioned to reinstall correctly.
